How to create Bill of Material by using Repeat Reason in CREO PARAMETRIC ?
2 Answer
Did you get your answer? it has been some time but I might be able to walk the process with you. It is easy when you know the steps. Yes, I can remember now. In the table you need to select the cell. there are two setting within Creo. one allows you to enter information in the cell the other allows you to set permaters for the cell. this will
help you understand. it is simple....watch contact me with additional questions. The repeat regions allows you to display the full BOM including sub assemblies.
