how to decide food packging filler speed for chilli powder packaging for diffrent kg variables ?
i am designing small domestic chilli powder packaging machine for variable kg, want to know more about gear drive speed, and some idea about how to decide filled material is at correct kg ?
i am experienced engineer in profile cutting and fabrication of heavy machinery, i have no much idea about automation.
Thanks in advance.
As you have not given any details of your chilli powder packaging machine, I do not know how it will work. I think that ajusting the mass of powder by adjusting the filling speed with gears would be a way too complex process. A better way would be to weigh the filled packages as they fill and then have the machine stop the filling once the desired filled package weight was achieved. A load cell and a switch system would be quite simple. It could also be achieved with some form of mechanical weighing system that would switch off once desired weight was reached. Once the filled package was moved off the filling point, an empty pack placed onto the filling station and the process started again.
Records are spared in various area so right now you are not ready to spare entire get together, to beat this circumstance you should utilize the "spare administration alternative" Please follow propositions ventures( from step 1 to stage 3) at that point you won't discover blunder or missing parts. https://dev.to/robin73328226/4-integral-things-you-must-be-aware-of-when-managing-your-chinese-supply-chains-fe4
