How to Design below part in CATIA??
Accepted answer
I don't have CATIA so I used Inventor but the principles should be the same
Step 1: create a block 40x40x70
Step 2: Extrude 20 by 45 ° (or use the chamfer function)
Step 3: Extrude 20 by 40 (or use the chamfer function)
Step 4: Extrude 20 by 40 (or use the chamfer function)
Step 5: Create a plane be 3 points
Step 6: Use the plane as a cutting tool
