How to Draw Twisted Circular Rotor
Any1 GIve an Idea about the Drawing given to be modelled in solidworks..
sweep comment using
fist sweep- then select profile- then path(guide line) - (below) option- select orientation type or twist -then select twist.
follow steps..
thank u
step for making twisted circular rod
1. make a helix upto your nedd ie.length pitch
2.sweep a circle on that helix by selecting corresponding plane
Make a helix path and sweep the profile, second option is twist along path.
Sweep the profile along the helix profile.
