I'm tired of going to Leaders>Custom Text Position>Broken Leader,Horizontal text, for every smart dimension.
Start a new part.
Edit the option for the item you mentioned above (I assume it is a part property)
Save the part as a new PART TEMPLATE, or overwrite the existing one.
Next time you start a model, that option will be set.
