How to make more than one part with same design which only differs in dimensions???
For Eg. - I want to make a shaft of 100mm,200mm,300mm,400mm and many more. this i want to do with only changing dimensions.. suggest i need this for my college project.. HELP....!!!!!!!!!!!!!!!!!!!!!!
If I understood your question. You can open folder which contains part you want to change. Copy that part multiple times and go to new copied parts and change dimensions as you wish.
Other way is to open that part you want to change. Change dimensions and then go "Save as" and choose folder and name of part, you may do it multiple times in one session. Important is not to save file as standard "Save" when you are finished with changing dimensions because that will change original file.
There is a way to change dimensions with equations, but you still have to use option "Save as", as far as I know.
Hope this helps.
