how to rotate an object in proe
i draw my piston in a straight plane but i want to rotate it to some inclination but i cann't do this so pls help me sir...............
Add planes and axis to rotate about. Or make an inclined plane to draw your piston on. If you post your native proe file I will take a look at it more. Or you can just message me about it.
you can use the "paste special" command for rotate a feature or whole model
you need to creat a axis as rotate datum. after that you can rotate an object.
Just use the paste special command
Watch this entire video, end of video available answer for your question.
https://www.youtube.com/watch?v=QXg2vRenaRQ&index=10&list=PLxiBY-0X9N8bsObxbN-YVxBfxPs3pAkJO
