How to set basic planes always visible on start up?
my 3 standard planes are hidden by default for new projects.
how can i set them to visible by default, so i dont need to unhide them every time i want to start a new model?
Start a new part file.
Show the planes you want to see (depending on the version, you can look under view - display, or view - Hide / Show
Once you are happy with the appearance, save the part as a Part Template (prtdot extension).
This is the same method you'd use to make an inch and a mm template, or ISO vs. ANSI template.
