how to simulate the cooling of a pv module with thermoelectric generators using matlab or ansys?
im not really familiar with the ansys work bench and matlab but i was advised that they can help in simulating the effects on temperature on the power output on mono crystalline solar cells. i want to attach the thermometric generators as heat sink to absorb the heat from the solar cells so that they operate at less temperatures thus giving a high efficiency
hi
you can find object of tutorial ansys or matlab in youtub
