How to use Catia Environment Editor?
Hi guys, may I know what's the use of this Catia environment editor? I read through the manual but not understand how to use it. The manual just guide us how to input command to make modification. Is there any guide on how to use it, how to input command? Sorry I am not administrator and IT guy, so this programming stuff is difficult for me. :( please help
Catia environment editor is the tool used for setting or changing the default working environment (user setting in general terms). It mainly depends on the requirement, you can set the default values of some variables as required to be changed frequently in a project, like just for an example in a Drafting project, you can set the default sheet size, text size, Angle of orientations, etc. to the required value instead of changing them multiple times. It is very helpful for maintaining the same settings for more than one systems just by creating an environment once and use it on all machines for the same results every time.
Not so much programming stuff is required for this.
