iLogic Frame Generator Code (Dynamically Supressing and Un-Supressing Sections)
How can I use frame generator with ilogic ? I am trying to create a wall cladding frame which has to dynamically adjust to the size of the wall whose values I enter via a form. Now I am facing a problem that every time I increase the size of the wall the number of partitions increase in the frame. I am able to reflect this change in the sketch that controls the frame but unfortunately I don't know how to make frame generator dynamically add or subtract sections as per the underlying sketch.
Hoi Alex,
maybe it is better to attach the file.
I think its easier for me to understand what you mean,
and so I can see wat is going wrong.
Regards,
danny
