In CATIA V5 ,while offseting the A class surface to B surface , some areas its NOT coming properly ,, how to get that unfilled surface
![suresh.s](https://d2t1xqejof9utc.cloudfront.net/members/avatars/846260/feed.jpg?1374552735)
thank you friend i understood , but i have one more doubt that,what are the commands can use for patch work?
![418ab476](https://d2t1xqejof9utc.cloudfront.net/members/avatars/missing_feed.png)
Hello Suresh,
That's depend upon then Offset distance and fillet size,
Please not clearly most of the unfilled area is in fillet location only,reason for this is- Fillet size in A-side surface is smaller than the Offset size. we Don't have other choice you have separately fill those area's in B-side surfaces.
One option is there, don't give any fillets in A-surface and then offset, then you can get clearly.
Note: we are not suppose to change anything in A-side surface,because A-side surface's from OEM.
I hope you can understand little bit from my answer.
