I have Pro-E Wildfire 5.0 version and need the drawings in that format only.
Hi,
3D files are easy to convert via STEP, IGES or SAT. 2D drawings are tricky. Normally you have to export them into DWG or DXF an import them in the application needed.
Hope this helps.
Tom
