Need Help Converting this into an STL or Something I can import into soldiworks
Our Designer sent me this 3D DWG file that he exported from 3D studio. I cannot seem to get it to export as an STL from autoCAD everytime I try the entire application crashes. Can someone help me out.
Thanks
Try AutoCAD 360 on my system I am getting the login error. You can download this from Autodesk site between this is done online. I am also having the same problem as you. but i think with lastest solid work version you can directly import AutoCAD files.
Dear Jason,
i have converted your file from dwg to stl from latest autocad.. i dont get any problem during conversion... hope this might help you when importing it in solidworks.
DHANASEKAR VINAYAGAMOORTHY
Happy to help always.....
regards,
Dhanasekar V
