Need Help on Getting Inertia Value (IozG) in exel File using Catia MACRO
Hi ,
I have created a macro for Extracting details of Assembly. Need help in getting Inertia value of Child parts (IozG) to Ms.Excel file.
Macro is attached. Kindly check it out and provide help for getting Inertia values also in to Excel.
Hi,
I don't understand macros, but I found this:
Inertia:
' COPYRIGHT DASSAULT SYSTEMES 2001
Option Explicit
' Purpose : Compute the mass and the center of gravity of a component.
' Assumptions : A CATProduct document should be active and a component selected.
' Author :
' Languages : VBScript
' Locales : English
' CATIA Level : V5R6
Sub CATMain()
' Retrieve the selected component
Dim oSelection As Selection
Set oSelection = CATIA.ActiveDocument.Selection
Dim oProduct As AnyObject
On Error Resume Next
Set oProduct = oSelection.FindObject("CATIAProduct")
If (Err.Number <> 0) Then
MsgBox "No selected product"
Else
On Error Goto 0
' Compute the inertia
Dim oInertia As AnyObject
Set oInertia = oProduct.GetTechnologicalObject("Inertia")
' Read the inertia data
Dim dMass As Double
dMass = oInertia.Mass
Dim dCoordinates(2)
oInertia.GetCOGPosition dCoordinates
' Display the results
MsgBox oProduct.Name & ": Mass = " & Cstr(dMass) & ", Center of gravity : X = " & _
Cstr(dCoordinates(0)) & ", Y = "+Cstr(dCoordinates(1)) & ", Z = "+Cstr(dCoordinates(2))
End If
End Sub
And Excel:
Sub CATMain()
'Creation d'un nouveau workbook Excel
Set oExcel = CreateObject("Excel.Application")
Set oBook = oExcel.Workbooks.Add
'Dans la première feuille excel, je plannifie les titres de mes collonnes
Set oSheet = oBook.Worksheets(1)
oSheet.Range("A1").value = "t en s"
oSheet.Range("B1").value = "nom_variable_maitre"
oSheet.Range("C1").value =" nom_variable_esclave"
oSheet.Range("A1:C1").Font.Bold = True
For i = 0 To 360 Step 1
Set partDocument1 = CATIA.ActiveDocument
Set part1 = partDocument1.Part
Set parameters1 = part1.Parameters
Set angle1 = parameters1.Item("maitre")
angle1.Value =i
part1.Update
oSheet.Cells(2+i, 2).value = parameters1.Item("maitre").Value
oSheet.Cells(2+i, 3).value = parameters1.Item("esclave").Value
Next
'et c'est fini pour excel
oExcel.Quit
End Sub
COURAGE
