I need to modify an Ipad Case to fit an Ipad 2 and 3.
Its a step file, and im having a hard time working with it. Ideally it would be someone with Solidworks.
I use Autodesk Inventor.
If you can help, please let me know and i will share the project here on Grabcad with you.
Hey Felix I hope you are doing well... if you want to share the modifications that you want to make I am able to work on SW12 & INV13
I might be able to assist you with it.
Best Regards
