Problem installing Solidworks 2013 x64 edition sp04
I have been struggeling with installing Solidworks 2013 sp04 64-bit on my laptop after I did a recovery of the computer (re-installing windows 7). I have ran windows update and checked all drivers that everything is up to date.
My first problem is that the install manager will not work. When I open the setup the manager starts, but there is only a clean window with the usual "solidworks" banner on top. I have tried different solutions by google'ing the problem, but nothing seems to help. Trying to reset internet explorer and set to default browser and etc..
But I can walk around this by starting the setup file in the folder swwi > data, and the setup starts and seems to work just fine until the very end where it says "the wizard was interrupted before solidworks 2013 x64 edition sp04"... It even created a desktop icon and everything before this message and after that it just deletes all solidworks files..
I tried to install the 2012 edition, with success. That is working perfectly, but since Im using solidworks for a school project and everyone else is using 2013, I cant use 2012..
Hopefully you understand my problem, and if anyone have experienced similar problems let me know!
I think its just wierd that 2012 works fine, and 2013 not at all.. Is there some major update in 2013 that is causing these problems?
Thank you for all answers!
Best regards
Andreas.
follow these steps
Answered with a tutorial: https://grabcad.com/tutorials/problem-installing-solidworks-2013-x64-edition-sp04
there are more steps
Answered with a tutorial: https://grabcad.com/tutorials/problem-installing-solidworks-2013-x64-edition-sp04--1
Thanks for response, Saad!
But how do I know what is useful or not..?
I got a tip about checking the install log file to determine what's causing the error. But I'm not very experienced with these kind of problems so I'm kind of shooting in the dark if you know what I mean.
Anyone know exactly where to find these install log files in windows 7, and what to look for regarding Solidworks installation?
Just worried to make things worse by messing up things I dont have a clue about, hehe.
Tried to follow the steps, but unfortunately it did not make any change..
I have now localized the install log file, and seems to be an error in "RegVal.exe". Please see the added file to read the complete log file.
What does this error accually mean? And is it a quick fix or complicated?
Thanks.
try this :
unistall SW2013
download ccleaner from piriform webpage
here is the link :
http://www.piriform.com/ccleaner/download/standard
once installed, run it, then on the left side there is an icon named register or something like this.
click on it
check for errors and fix errors (by deleting missing entries)
go in the folder where solidworks had been installed and make sure that no file still exist : delete folder.
To finish, run your illegal version of SW2013 following ALL the instructions, copy the files in the destination folder of the install.
Run SW
Have fun
Still problem with SW2013 on my laptop..
Maybe just buy a new laptop...? Hah..
Google'd regval.exe error and seems that its a quite common problem. Found some programs that automatically fix regval.exe (Advanced Fix 2013), but thats a program that you need to buy before use. Is it worth a try, or is it just the same as ccleaner?
OK, This sounds like a problem That I had previously ran into with SW2008, SW2009, pretty much anything after SW2007.
If it is the problem I am thinking about then it is a Windows problem not a solidworks problem. It has to do with the version of Microsoft Visual C/C++ Redistributable that is currently installed in windows. Check to see if it is the latest version. If it's not, then download and install the latest version and try again.
Here is a somewhat crude roadmap of what is happening.
SW installation manager comes to the point where it installs Visual C/C++
Redistributable Ver 4.0. If your laptop has Ver 2.0 installed, but not ver 3.0, the install manager will not have the proper library to incorporate ver 4.0 into. (This may be what the VBA warning towards the end of the log is all about) Upon failure to find the previous consecutive version it skips the installation of Visual C/C++ which is what links the solidworks library to the windows library. This is the last thing it does on the install, so if it fails it will create exactly the situation that you are describing. Check microsofts website about this problem. They may have some more info.
Good luck.
