problem wile opening a solidworks file
Hi all,
I'm trying to open this file Engine_21083
with solidworks 2014 but I can't. Does anyone know why?
thanks!
Hi all,
thanks!
Here is the assembly file in STEP format. You should be able to open this in SW2014 but will not have the feature tree - only dumb solids with the geometry.
So far that I understand, these files were created in Solidworks 2016, at least so says the property. Hence, you will not be able to open it.
