Problems with Sprockets
I am using the sprockets designer of solid edge, this tool don't give me the chain. So I decide to make the model of the chain. After I put all datas and generate the sprockets and the chain, I make the assembly. But when I put the second constrain in the roller in the sprockets, the software show a mensage saying that the relationship make conflict with others constrains.
The problem is not in the model because the designer give to me information about the chain and I checked all values. My objective is make a beautiful assembly, I don't use it to make a simulation.
I use the tool mesure to checck the values of sprockets and the distance of rollers and they are right.
Someone have any idea of what is happen?
Check again the dimensions but this time with more decimals, probably there is a 0.00000001 diference and Solid Edge doesn't like it.
