I am exporting the attached file (named as "tanque 30 litros") to SolidWorks. But I am not getting to convert in a solid body with a smooth surface (the result is in the other attached file). What can I do to merge this body?
It's a mesh model with faceted surfaces. You can't get a smooth solid surface from it out of AutoCAD.
