state difference between molding and casting??
2 Answer
Casting is usually refered for the process with Metals, while molding is refered for plastics. The processes are slightly different, but working and implementation is same.
Plastics and metals....... Both are quiet different processes...... You cant cast metallic parts with molding machines...... Similarly, Plastics wont give that good surface finish in Sand molds...... Material used are different with different properties.... thus different names....
