Thikness in catia structure functional object design workbench does not appear
shell, deck structure & plate thickness in the structure functional object design workbench does not appear. I used catai V5-6R2018, but at times I used V5R20 or V5R21 everything was fine. What should I do? Thanks..
The attached image shows the Wireframe and Surface Design workbench is active. I suggest you start by choosing the correct workbench to find the tools you're looking for.
