Tolerance & stack up Analysis - explain with tutorial
Can any one explain a Tolerance & stack up Analysis through
SOLIDWORKS software
with simple models, a step by step tutorial.
If you're referring to the TolAnalyst add-in, there is a tutorial included with the Solidworks software. Go to Help>Solidworks Tutorials>click the 'All SOLIDWORKS Tutorials' tab and select TolAnalyst Tutorials.
Be warned though, unless it has been improved recently, if used on anything beyond the most basic and simple parts and assemblies, it is junk. Back when I was looking into it I couldn't find a single place where it was being used to any degree of success. Any attempt I made to use it on our designs quickly became a crash fest.
