Tutorial: how to model a spiral in Solid Edge (example 1: draw the spiral path)
this tutorial was requested here: https://grabcad.com/requests/cylindrical-cuve
In this tutorial you will need to draw the spiral path. Here is a second version of this tutorial that uses the helix command: https://grabcad.com/questions/tutorial-how-to-model-a-spiral-in-solid-edge-example-2
The spiral is modeled with a sweep command.
Answered with a tutorial: https://grabcad.com/tutorials/tutorial-how-to-model-a-spiral-in-solid-edge
for an example using the helix command, take a look here:
https://grabcad.com/questions/tutorial-how-to-model-a-spiral-in-solid-edge-example-2-using-helix-command
