Why change drawing feature to convert from IGS to DXF file?
I have a IGS file of circles feature. I convert IGS to DXF in Solidworks. When I open DXF in AutoCAD, change shape of circle feature like line-line connect.
What to do for convert same as IGS as in DXF?
I attach IGS file.
Accepted answer
Strange things are going on here; maybe there are some unsupported data in the IGS-file? I imported the IGS-file into Solidworks, created a 3d-sketch, selected all curves, and used the Convert Entities-command. Then I extruded a short (1 mm) surface using the 3d-sketch with the front plane as directional input. I finally exported this surface as a DXF file and this has nice, smooth curves, please see attached...
