Advanced Catia sheetmetal
This tutorial provides sheetmetal introduction and toolbars available with explanation.
Step 1: Contents To be discussed
1.Introduction Sheet metal Introduction
2.Primary walls and secondary walls
3.Sheetmetal parameters
4.K factor and Y-factor
5.Various sheet metal tools
6.Creating sheet metal components
Step 2: Parameters
Sheet metal depends on certain parameters
1.Thickness
2.Bend Radius
3.Bend angle
Step 3: Bend Allowance Formula
L= ᴫ/2 * R + (Y*T)θ/90
Where:
L= Developed length
R=Inside Radius
T=thickness
Θ=Bend angle
Y=Y-factor
Step 4: Y-factor
Y=K* ᴫ/2
Default value will be 0.5
In CATIA k-factor value is around 0.4005
Step 5: Mouse Controls
Step 6: Entering Sheetmetal Parameter
Step 7: Default Bend Allowance value
K Factor
Physically, the neutral fiber represents the limit between the material compressed area inside the bend and the extended area outside the bend. Ideally, it is represented by an arc located inside the thickness and centered on the bend axis.
This formula can be deactivated or modified by right-clicking in the K factor field and choosing an option from the contextual menu. It can be reactivated by clicking the Apply DIN button. Moreover, the limit values can also be modified.
Step 8: Various Bend Extremities
Step 9: Various Bend Extremities
Ø Minimum with no relief (default option): the bend corresponds to the common area of the supporting walls along the bend axis, and shows no relief.
Ø Square relief: the bend corresponds to the common area of the supporting walls along the bend axis, and a square relief is added to the bend extremity. The L1 and L2 parameters can be modified if needed.
Ø Round relief: the bend corresponds to the common area of the supporting walls along the bend axis, and a round relief is added to the bend extremity. The L1 and L2 parameters can be modified if needed
Ø Linear: the unfolded bend is split by two planes going through the corresponding limit points (obtained by projection of the bend axis onto the edges of the supporting walls).
Ø Tangent: the edges of the bend are tangent to the edges of the supporting walls.
Ø Maximum: the bend is calculated between the furthest opposite edges of the supporting walls.
New Functionalities
Local fold and unfold of bends – We can now fold planar faces, as well as unfold cylindrical or conical faces in folded views, without changing the flattened view.
Overlap detection - A new command now lets you check overlapping areas on flat views.
Mirror - We can now mirror a given sheet metal feature. This duplicates a sheet metal feature symmetrically with respect to a plane.
Hybrid Design - We can now create wireframe and surface features within the same solid body which impacts the behavior of overlapping and local fold/unfold of bends.
Step 10: Enhanced Functionalities
Cutouts
Additional possibilities are now available when creating a cutout: We can choose a direction for the cutout that is different from, or equal to, the normal direction. Additionally, the extrusion can now be of lesser length than the thickness. We can also now specify several supports for the cutout, instead of just one previously.
Stamp recognition
Stamps can now be recognized as Generative Sheetmetal Design stamps.
Half-pierce for stamps
The new half pierce feature is available for circular stamps, curve stamps and surface stamps.
New options for surface stamps
Additional possibilities are now available when creating surface stamps. We can now define a stamp based on profile containing a punch and die sketch, a 3D curve sketch or a sketch with several inner contours.
Flange pattern
We can now create a pattern from a flange on rectangular, circular or user-defined patterns.
Hopper
Selecting a ruled surface is now possible when creating a hopper.
Document chooser integration
We can now customize the document environment (Tools > Options > General > Document tab) in order to select documents or paths using various interfaces (folder, Enovia, and so on). The interface can be customized for a folder or DLName path selection interface
Step 11: Creating Walls
Step 12: Rolled Walls
Surfacic hoppers are defined by a ruled surface selected by the user or created thanks to the loft command.
Defining a surfacic hopper via a loft is highly recommended since it allows detection of all canonical segments. The two sketches used to define the loft can be on parallel or non parallel planes.
The reference wire and the invariant point, used to unfold the hopper, must lie on the surface, as well as the tear wire.
Step 13: Different Workbenches
Step 14:
Step 15:
