ANSYS Tutorial 2022 : Bevel gear analysis using Ansys Workbench 2022
A bevel gear is a toothed rotating machine element used to transfer mechanical energy or shaft power between shafts that are intersecting, either perpendicular or at an angle. This results in a change in the axis of rotation of the shaft power. Aside from this function, bevel gears can also increase or decrease torque while producing the opposite effect on the angular speed.
https://www.iqsdirectory.com/articles...
Step 1: ANSYS Tutorial 2022 : Bevel gear analysis using Ansys Workbench 2022
