Ansys Tutorial - CFD Of Venturi 2D Using Fluid Flow (Fluent) Module
Small
In this tutorial I have made a 2D shape of a venturi using the same software.
You will see the changes in the velocity and pressure at the throat region of the venturi , as the fluid reaches the throat region the pressure drops and the velocity increases.
Please log in to add comments
  • Feed
    Felix Atachahua
    Hi, excellent. Please , Could you tell me how I can to get a plot in Ansys like Moment-rotation in a solid?
    October 16th, 2017 17:21
