Autocad 2d drafting | Autocad Practice Exercise 6 | Create dimensions in Autocad | CADable Tutorials
Autocad 2d drafting | Autocad practice exercise 6 | Autocad dimensions
Hi friends welcome back to CADable. This is Engr. Ibrahim Omer. In this tutorial, we will learn how to make a 2d drawing in autocad. This is autocad practice exercise 6. I hope you like it. We will learn the following features and commands:
1) Use of Layers Autocad
2) Line Weight
3) Offset Command
4) Tangent line Autocad
5) Autocad slot at angle
6) Trim command
7) Tan Tan Radius
8) Annotate Centre Mark
9) Autocad Dimensions
10) Multiline text Autocad
It is a good exercise for beginners and it will be a good practice for beginners. Kindly use play pause technique for practice. Feel free to ask your queries in comment section. I will try to answer each and every question. Keep practicing as practice makes a man perfect.
Follow these tutorials, how to create layers in Autocad.
Autocad practice exercise 2 | Orthogonal projections | Layers in Autocad | Isometric to orthographic
https://youtu.be/D9XNiRnMbmQ
Autocad 2d drawing practice-Convert Autocad DWG to PDF-How to create layers in Autocad-CADable
https://youtu.be/dGXUVW6sfWI
Follow our Channel:
https://www.youtube.com/c/CADable
#autocad2ddrafting #autocadpracticeexercise6 #autocad2dpracticedrawing #CADable #CADabletutorials
