Basic Tutorial for AutoCAD-3
This Tutorial will give you idea about basic introduction about AutoCAD, user guide tutorial for tools, best practices, applications.
This tutorial is the web series for basic AutoCAD so follow up for the next file.
Hit like if it is useful.
Step 1: Drawing Tools
This is the continuation of drawing tools commands in AutoCAD
Ellipse
We can create ellipse in many ways in AutoCAD
It can be used by giving EL enter in the command prompt
Centered ellipse
Axis and End ellipse
Elliptical Arc
Hatch
Using hatch command in AutoCAD we can shade the enclosed area to show its material availability or depends upon the requirements.
hatch command can be used by entering H enter
Normal hatch
select the type of hatch pattern from the list
Gradient
select the gradient style and two primary colors for gradient
Boundary
Tips
In AutoCAD we can able to give the hatch transparency, hatch angle, associativity etc.,
Step 2: Additional drawing tools
Construction line
This line can be create by using XL or XLINE enter. It may be horizontal, vertical, bisecting or at specific angle.
Ray
This is used to create an infinite line from a defined point by giving RAY enter
Multiple points
This can be used by giving PO enter in the command prompt
Divide
This can be used by giving DIV enter in the command prompt
Measure
The shortcut used for measure is ME enter in the command prompt
Region
The shortcut for region command is REG enter
Wipeout
This can be used by giving wipeout in the command prompt
3D polyline
3dpoly enter to use the 3d polyline
Helix
Enter helix in command prompt to create a helix
Tip
we can able to give twist angle, turns, turns height, axis endpoints of the helix.
Donut
Enter DO enter in command prompt to create a donut
Revision cloud
Enter revcloud to create revision cloud of any specified shape
there still poly shape and freehand revision cloud.
Spline
Spline curves are used to create irregular curves they are of two types
1.Spline fit
2.Spline CV
spl enter is the shorcut for spline and it can be created using methods, knots, objects.
