Bottom Of The Stand Tutorial
This is a step-by-step tutorial for making Bottom of The Stand on office chair. This design was made for Visualization and Modelling class.
Vegantra Amayko Siaga
2106658811
Step 1: Make a Circle
Make a circle with diameter of 50 mm
Step 2: Extrude
Next extrude the circle with length of 120 mm
Step 3: Insert a Plane
Next insert the Offset From Plane and set it to 60 mm
Step 4: Make a Circle On The Plane Surface
Make a circle on the plane surface with diameter of 30mm
Step 5: Extrude The Circle on Plane Surface
Extrude the circle with length of 10 mm
Step 6: Loft the both shape
Next, we use loft feature to connect both shape by pressing the line that will connect on both model
Step 7: Fillet The Top
Next step is fillet the top with 5 mm constant radius edge sets
Step 8: Make a Hole Inside the Cylinder
To make a hole inside the cylinder, first we make a 2D Sketch of circle with 30 mm diameter
Step 9: Extrude to The Cylinder
Extrude the circle by 94 mm through the cylinder
