CATIA V5 - Assembly Design tutorial
The tutorial uses a simple LEGO car as an example, but the same principles can be applied to assemble any complex assembly.
The tutorial is designed for beginners who are new to CATIA v5 Assembly Design Workbench. It assumes that you have a basic understanding of how to use CATIA v5.
Step 1: Learn by doing
The case study has a high amount of parts, and the best approach is to follow the reference video and add one constraint at a time.
This is not the only solution regarding this Lego car assembly! As with constraints they can be defined either by planes, edges, surfaces, etc.
You can find the video in the video description or directly on my account at:
https://grabcad.com/library/simple-lego-car-2
