CATIA V5 - Create and Edit geometrical shapes
Basic overview video regarding geometrical shapes available within Imagine and Shape Workbench
Step 1: Basic primitives
To create and edit geometrical shapes in the Imagine & Shape workbench in CATIA V5, you can use the following steps:
Creating a geometrical shape
- Open the Imagine & Shape workbench.
- Click the Create button on the toolbar.
- Select the type of geometrical shape you want to create from the list.
- Click in the 3D view to define the first point of the shape.
- Continue clicking to define the remaining points of the shape.
- Press Enter to finish creating the shape.
Editing a geometrical shape
- Select the geometrical shape you want to edit.
- Click the Edit button on the toolbar.
- Select the type of operation you want to perform on the shape from the list.
- Depending on the operation you select, you may need to specify additional parameters.
- Click OK to perform the operation.
Here are some specific examples of how to create and edit geometrical shapes in the Imagine & Shape workbench:
Creating a plane
- Select Plane from the list.
- Click in the 3D view to define the first point of the plane.
- Click again to define the second point of the plane.
- Click a third time to define the normal vector to the plane.
- Press Enter to finish creating the plane.
Editing a plane
- Select the plane you want to edit.
- Select Translate from the list.
- Specify the new position of the plane.
- Click OK to translate the plane.
Creating a sphere
- Select Sphere from the list.
- Click in the 3D view to define the center of the sphere.
- Specify the radius of the sphere.
- Press Enter to finish creating the sphere.
Editing a sphere
- Select the sphere you want to edit.
- Select Scale from the list.
- Specify the new scale factor for the sphere.
- Click OK to scale the sphere.
Creating a cylinder
- Select Cylinder from the list.
- Click in the 3D view to define the center of the cylinder.
- Specify the radius and height of the cylinder.
- Press Enter to finish creating the cylinder.
Editing a cylinder
- Select the cylinder you want to edit.
- Select Revolve from the list.
- Specify the new axis of rotation for the cylinder.
- Click OK to revolve the cylinder.
These are just a few examples of how to create and edit geometrical shapes in the Imagine & Shape workbench in CATIA V5. For more information, please consult the CATIA V5 documentation.
https://dokumen.tips/documents/tutorial-imagine-and-shape-catia-v5.html
