Class 1 - Solidworks Simulation - The Analysis Process and Introduction to Finite Element Analysis
see video below
Hello everyone, welcome to the SolidWorks Simulation training a
I will be with you during training objective of
this training and teach how to use solidworks simulation software to analyze
static structural party behavior and advantages within solidworks we will focus
on fundamental skills and concepts central to good use of solidworks simulation
software beauty Let's start then and to begin to understand some basic concepts
the first tip What is solidworks simulation? Solidworks simulation is a project analysis
tool based on a numerical technique called finite element analysis
or faith and this numerical analysis will indicate whether an assembly part or structure will resist the
loads that are being applied to them beauty we also have a cycle here and in this cycle it shows
the intention of our Solid Work Simulator it has an intention an objective for us to stop we get
the best possible prototype The prot ideal type faster so with this dynamic that
we have all the practical tests 7 that would be carried out Enchantment will be carried out within the
virtual environment of solidworks beauty people at hand let's continue so he talks a little bit now
about the evolution of sodium Simões first there in 1982 came Mrs té that was the first simulation software
because of seeing finite element analysis existing in the market for computers
then in 1995 1frs make its first main Soccer finite element analysis software in
the market and with that it becomes partner of solidworks Corporation and from there Cosmos work
Beleza was born later in 2001 with due worldwide success of Cosmo Words the Systems action which was
the company responsible for the solidworks Corporation's purchase, also ends up acquiring
the SRS the company SRS to Aim 2003 the merger of SRS with solidworks Corporation and finally
they become one and the same thing and there in 2009 we got the rename from Cosmo worx to solidworks simulation good moving
on a little bit now we're going to talk a little bit about the versions of the
solidworks simulation first version that we have in the sun and 8 excellent in the standard and in it
we have tactical analysis for parts and assemblies fatigue analysis solidworks motion also so
a very interesting software for motion analysis and then we have a single Leader who
simulated flooring for Fashion that already has other types of analysis within it analysis frequency
analysis buckling thermal analysis Ah and finally a Solid works in Black champagne E then we have already entered
the non-linear analysis part and the composite analysis part reminds us here all
software all higher version case solids pro Fashion it will contain everything that has all kinds
of tools that have inside the software solid garbage protects no sorry and the solidworks
simulation stander A software so always the above version will encompass the previous version the same thing as
the pin Solid Work Simulator a tire will have the Simulator features festoon top Coroner
beauty good inside teaching speak I use a lot about linear static analysis what it
encompasses Linear static analysis firstly the results are proportional to the applied loads
ie if I double mine applied load my result will be reported high and it
will always keep the aspect ratio if it doesn't keep the aspect ratio then it's no longer running away
from linear static analysis I'll be entering static analysis not winning as you can
observe in place too we have a material material and it will always be linearly elastic,
ie the physical and mechanical properties of the material will change according
to the loads regardless of the loads received, they will always receive the same material such as
flow limit it will be fixed beauty and finally the loads all loads are
static i don't have a shape in a dynamic applied load mind to it, it will always be
slow and gradual until it reaches its maximum point that's why we don't talk about impact, we do n't
even talk about Lu, it's good so we can have a small displacement in relation to the size
of the project, well, you understand a little more about finite element analysis we have a small
question for you how do you measure distance from your home to another place you want there, well
we know that it is not simply drawing a straight line from your origin to your destinations as we
