Design Bolt in CATIA
How to create bolt in CATIA
Choose the plane you want to work in(in this case I chose xy plane) enter the Sketch mode.
Draw a hexagon and make sure that dashed line coincides with horizontal or vertical axis.After that use Constraints (use dimensions that you need)
Note: In case If you need to constraint it like this It will show that this sketch is over constrained.So I deleted the circle in which the hexagon was inscribed and added the constraints I needed.
After that select these edges and axis,go to Constraints Defined in Dialog Box and select Symmetry
Repeat the same process on these edges too.
After that you should have a fully constrained sketch
Exit workbench
Use Pad
Select the plane in which you will add the body and enter the Sketch mode
Draw the circle in the center and constraint it
Exit workbench
Use Pad and enter the dimension you need
To chamfer the edges of the head,click on the plane where you can see two sides like this
After that use Project 3D Elements on this edge (or the edge on the other side of axis)
Use Line to draw something like this and constrain the angle
Also add Axis
Then you can exit workbench and use Groove
And this is the chamfered edge
To add the thread simply use Thread/Tap command
I used in this case Metric Thick Pitch M16 just to show how this works
