Design of Radial Engine With CATIA
Radial motor design is designed as mentioned below.
We open Catia and enter the part desing menu first.
And from here we enter the sketch at xy from the product tree. Then we make the skeleton drawings that we are seeing below in the direction of the given meter.
We record every track we make under a specific file.
shaft
Main rod
piston
Top Bush Button And Alt Bush Bush Button ,Piston Plug Pin ,Piston Pin, Connecting Pin, Main Lever Bearing, Connecting Pin
After we have made the necessary pieces on the Part design menu, we're done here.
We will do it in Sarad, we invite them to the product part, ie the product menu, and here we combine the parts as follows. -
Creating and Linking Parts; Piston , Piston Ring , Connecting 4 Piston Rings to Piston
Top and Bottom Bushing Rods
Articulation Shaft
Combination of Upper and Lower Bushing Rods and Joint Shaft
Piston pin and piston plug pin
Piston and Articulated Milinin Merger
Main Rod Rod
Main Arm Bed
Connecting Piston with Main Rod
As a result, we make the radial motor this way.
