Designing an IMPELLER using CATIA V5
Beginner-level CATIA V5 tutorial aimed at improving your 3D modelling skills to the next level. I tried to simplify the steps while making the workflow as efficient as possible. At the end of this tutorial, you would be able to:
1. Create Points
2. Create Splines
3. Create revolute surfaces
4. Create Projections curves along a direction and normal to surface
5. Create Multi-Sections Surfaces
6. Split a curve using point on curve
Feel free to comment or share my profile and this tutorial link to your circle of influence.
Step 1: Before you start...
1. Your units are set to English. Go to Tools -> Options -> Parameters and Measure -> Units -> change length unit to inch
2. Choose Generative Shape Design (GSD) workbench and create a new part with ‘Create a geometrical set’ option is active
Step 2: Create a new axis system: Axis System.1
1. Select Axis System from Insert menu
2. Click OK
Step 3: Create 5 points: Point.1 – Point.5
1. Double-click on Point command icon
2. Create 5 points on plane YZ according to these values:
a. H: 0.00, V: 2.00
b. H: 0.10, V: 1.98
c. H: 0.70, V: 1.20
d. H: 1.50, V: 0.20
e. H: 2.60, V: 0.00
3. Press Esc keyboard
Step 4: Create a spline connecting all points above: Spline.1
1. Click on Spline command icon
2. Multi-select Point.1 – Point.5 from the specification tree
3. Add tangent direction in Y-axis for the last point in the spline definition list
4. Click OK
Step 5: Create a revolve surface: Revolute.1
1. Click on Revolve command icon
2. Select Spline.1 as the Profile
3. Select Z-axis as the Revolution axis
4. Enter 360deg as Angle 1
5. Click OK
Step 6: Create offset plane: Plane.1
1. Click on Plane command icon
2. Select plane XY as the Reference
3. Enter 1.5 as the Offset
4. Make sure the plane is upward from origin (click Reverse Direction if not)
5. Click OK
Step 7: Create 4 point: Point.6 – Point.9
2. Create 5 points on Plane.1 according to these values:
a. H: -0.20, V: 0.59
b. H: 0.25, V: 1.00
c. H: 0.70, V: 1.80
d. H: 1.25, V: 2.165
Step 8: Create a spline connecting all points above: Spline.2
2. Multi-select Point.6 – Point.9 from the specification tree
3. Click OK
Step 9: Create projected curve on Revolute.1: Project.1
1. Click on Project command icon
2. Change Projection Type to Along a direction
3. Select Spline.2 as the Projected
4. Select Revolute.1 as the Support
5. Select Z-axis as the Direction
6. Make sure Nearest solution is checked
7. Click OK
Step 10: Create 4 point: Point.10 – Point.12
a. H: 1.30, V: 2.00
b. H: 1.80, V: 0.50
c. H: 2.50, V: 0.20
Step 11: Create a spline connecting all points above: Spline.3
2. Multi-select Point.10 – Point.12 from the specification tree
3. Click OK
Step 12: Create a revolve surface: Revolute.2
2. Select Spline.3 as the Profile
5. Click OK
Step 13: Create normal projection of Project.1 onto Revolute.2: Project.2
2. Change Projection Type to Normal
3. Select Project.1 as the Projected
4. Select Revolute.2 as the Support
5. Make sure Nearest solution is checked
6. Click OK
Step 14: Create line connecting 2 curves: Line.1
1. Click on Line command icon
2. Select start point of Project.1 as Point 1
3. Select start point of Project.2 as Point 2
4. Click OK
Step 15: Create multi-section surface: Multi-sections Surface.1
1. Click on Multi-Sections Surface command icon
2. Select Project.1 and Project.2 as the Sections
3. Select Line.1 as the Spine
4. Click OK
Step 16: Create a circular pattern: CircPattern.1
1. Select Circular Pattern from Insert -> Advanced Replication Tools
2. Click on Multi-sections Surface.1
3. Enter 18 as Instance(s)
4. Enter 20deg as Angular spacing
5. Select Z-axis as Reference element
6. Click OK
Step 17: Rotate curve 10deg along the Z-axis: Rotate.1
1. Select Rotate from Insert -> Operations
2. Select Project.1 from the specification tree as Element
3. Select Z-axis as Axis
4. Enter 10deg as Angle
5. Click on Hide/Show initial element
6. Click OK
Step 18: Rotate curve 10deg along the Z-axis: Rotate.1
6. Click OK
Step 19: Rotate curve 10deg along the Z-axis: Rotate.2
2. Select Project.2 from the specification tree as Element
6. Click OK
Step 20: Create point on curve: Point.13
1. Click on Point command icon
2. Click on Rotate.1 from the specification tree
3. Enter 1.00 as Length
4. Click OK
Step 21: Create point on curve: Point.14
2. Click on Rotate.2 from the specification tree
3. Enter 1.30 as Length
4. Click OK
Step 22: Create split curve: Split.1
1. Select Split from Insert -> Operations
2. Select Rotate.1 as Element to cut
3. Select Point.13 as Cutting elements
4. Make sure the orange-colored curve preview is at the lower part (click Other side if not)
5. Click OK
Step 23: Create split curve: Split.2
2. Select Rotate.2 as Element to cut
3. Select Point.14 as Cutting elements
5. Click OK
Step 24: Create line connecting 2 curves: Line.2
2. Select start point of Split.1 as Point 1
3. Select start point of Split.2 as Point 2
4. Click OK
Step 25: Create multi-section surface: Multi-sections Surface.2
2. Select Split.1 and Split.2 as the Sections
3. Select Line.2 as the Spine
4. Click OK
Step 26: Create multi-section surface: Multi-sections Surface.2
4. Click OK
Step 27: Create a circular pattern: CircPattern.2
2. Click on Multi-sections Surface.2
6. Click OK
Step 28: Create a circular pattern: CircPattern.2
6. Click OK
Step 29: Rotate curve 10deg along the Z-axis: Rotate.3
4. Enter 5deg as Angle
5. Click OK
Step 30: Rotate curve 10deg along the Z-axis: Rotate.4
5. Click OK
Step 31: Create point on curve: Point.15
2. Click on Rotate.3 from the specification tree
3. Enter 1.50 as Length
4. Click OK
Step 32: Create point on curve: Point.16
2. Click on Rotate.4 from the specification tree
3. Enter 1.93 as Length
4. Click OK
Step 33: Create split curve: Split.3
2. Select Rotate.3 as Element to cut
3. Select Point.15 as Cutting elements
5. Click OK
Step 34: Create line connecting 2 curves: Line.3
2. Select start point of Split.3 as Point 1
3. Select start point of Split.4 as Point 2
4. Click OK
Step 35: Create multi-section surface: Multi-sections Surface.3
2. Select Split.3 and Split.4 as the Sections
3. Select Line.3 as the Spine
4. Click OK
Step 36: Create a circular pattern: CircPattern.3
2. Click on Multi-sections Surface.3
3. Enter 36 as Instance(s)
4. Enter 10deg as Angular spacing
6. Click OK
Step 37: Clean-up
Make all the necessary clean-up to make sure only related surfaces are visible.
