Dice Modelling using Fusion 360.
Dice design using Autodesk Fusion 360 , ready for 3D printing.
Step wise instructions for beginners of Fusion 360.
Enjoy and Keep learning :)
Let me know if you have any queries or question.
Step 1: Start Autodesk Fusion 360.
Step 2: Now go to Sketch panel and Select Create sketch.
Step 3: Now select the plane on which you want to draw sketch.
Step 4: Now again go to sketch panel and select Center Rectangle and draw a rectangle of equal sides 10mm.
Step 5: Draw rectangle
Step 6: Click on the Stop sketch.
Step 7: Now go to Modify panel and select Press Pull command.
Step 8: Select the profile and specify Extrude Distance equal to the rectangle size 10mm and press OK.
Step 9: Now again go to Modify panel and select Fillet command.
Step 10: Now select the all 12 Edges of the Cube and specify fillet radius and press OK.
Step 11: Now select the Front face of the Cube and go to Create sketch command.
Step 12: Now create four circles on Front face of diameter 1.5 mm as per below image and click on the STOP Sketch command.
Step 13: Now again go to Modify panel and Select Press Pull command .
Step 14: Select the four circles and specify Extrude distance and select operation as New body and press OK.
Step 15: Now again go to Modify panel and select Move/Copy command.
Step 16: Now select the four cylinders and move it along Negative Z-axis by 1 mm and press OK.
Step 17: Now go to Modify panel and Select COMBINE command.
Step 18: Select the Target body as CUBE and Tool bodies as Four Cylinders and select Operation as CUT and press OK.
Step 19: Dice will look something like this.
Step 20: Now select top face and select Create Sketch command.
Step 21: Now select the Circle command and create sketch similar to the below images and Click STOP SKETCH command.
Step 22: Now again go to Modify panel and Select Press Pull command.
Step 23: Now select all the sketch profile on the TOP face and specify Extrude Distance as 0.5mm in Negative Y-Axis direction and select Operation as CUT and press OK
Step 24: Congrats!! Now you have a six sided die with your own custom symbol on one side.
