Electric Socket
Tutorial how to make a electric socket as a part of the study lamp
Step 1: Draw the line sketch according to the size of the line that has been determined
Step 2: Mirror the line sketch and use the middle line as the constrain line
Step 3: Extrude the sketch with 10 mm length
Step 4: Fillet all of the side edges with the predetermined size
Step 5: Draw the following sketch with the predetermined length of line on the front of the socket body
Step 6: Extrude the sketched part with 5 mm length
Step 7: Fillet the second part edges with the predetermined size
Step 8: Create two circle sketches and a vertical middle constrain line with the predetermined size
Step 9: Extrude the circle sketches around 10 mm length
Step 10: Create another extra circles on the front of the earlier circles and extrude it with 10 mm length also
Step 11: Fillet the edges with 2 mm length
