EXTRUDE NX TUTORIAL || SKETCH || DIRECTION || LIMITS || BOOLEAN || DRAFT || OFFSET || NX SIEMENS
🚀 Master the Extrude Command in NX Siemens! In this tutorial, we dive deep into the Extrude feature and its related commands in Siemens NX CAD software. Whether you're a beginner or an experienced user, this step-by-step guide will help you understand how to create and modify 3D models using extrude operations efficiently.
🔹 What You'll Learn:
✅ How to use the Extrude command effectively
✅ Understanding Boolean operations (Unite, Subtract, Intersect)
✅ Working with Draft & Offset options in extrude
✅ Advanced extrude settings for precision modeling
✅ Related commands like Sweep, Revolve, and Shell
✅ Pro tips for better design workflow in NX Siemens
