Headrest Connector Tutorial
This is a step-by-step tutorial for making headrest connector on office chair. This design was made for Visualization and Modelling class.
Vegantra Amayko Siaga
2106658811
Step 1: Make a Circle
Make a circle in 2D Sketch with diameter of 12,8 mm
Step 2: Extrude The Circle
Extrude the circle by 80 mm
Step 3: Insert a Plane
Insert a plane on bottom surface and set it to 32 mm
Step 4: Make a Circle on The Plane and Extrude
Now make a circle on the plane with diameter of 25 mm and extrude it with 2 mm length
Step 5: Chamfer
Now use chamfer feature and set it to 2 mm in the shape before.
Step 6: Chamfer The Top
Now chamfer the top surface and set it to 2mm
Step 7: Make a Thread
Use Thread feature and input the number as shown below
