How to Build Your Own Quadcopter Drone at Home for Beginners- Part 2
BUILD A QUADCOPTER IN JUST 5 EASY STEPS. THE STEPS ARE EASY TO UNDERSTAND WITH MULTIPLE PICTURES AT EACH AND EVERY STEP. ALSO THE REQUIRED COMPONENTS DETAIL GIVIEN IN THE YOUTUBE VIDEO DESCRIPTION.
The quadcopter shown above is a simple type of multicopter, with each motor/propeller rotating in opposite directions from the two motors on either side of it (i.e. motors at opposite corners of the frame rotate in the same direction).
A quadcopter can control its roll and pitch rotation by speeding up two motors on one side and slowing down the other two. For example, if the quadcopter wants to roll to the left, it will speed up the motors on the right side of the frame and slow down the two on the left. Similarly, if it wants to spin forward, it speeds up the rear two motors and slows down the front two.
The copter can turn left or right by speeding up two motors that are diagonal to each other and slowing down the other two.
Horizontal movement is accomplished by temporarily speeding up/decelerating some of the motors so that the vehicle leans in the desired direction of travel and increases the overall thrust of all the engines so that the vehicle moves forward. Generally, the more the vehicle leans, the faster it travels.
Altitude is controlled by accelerating or decelerating all motors simultaneously.
PART 1 LINK:
https://youtu.be/19V4oBooOhU
PART 3 LINK:
It will be uploaded soon...
Warning:--- This video is for educational purposes only. Do not attempt to recreate the actions in this video as they are dangerous if not performed correctly and may result in serious injury. If you are confident on the information shown in this video, you are responsible for the results. Have fun, but always think ahead and remember that every project you attempt is at your own risk.
For more details contact email: rambo.tss19@gmail.com
WhatsApp:7548875553
Step 1: Chose Right Motor
Step 2: Chose Right Propeller
Step 3: Chose Right ESC
Step 4: Chose Right Control Board
Step 5: Chose Right Battery
Step 6: How to Build Your Own Quadcopter Drone at Home for Beginners- Part 2
