How to Convert pdf file into AutoCAD | Insert pdf file in Autocad 2022 |In Englis
Dear Guys:
If you want to convert PDF plan file into AutoCAD files to edit or some other work on plan, here is the right video for you. watch this video and follow same steps in AutoCAD 2022.
Use latest software as possible i used 2022 version of Autodesk AutoCAD.
in this video. i have used different tool to set the units,
and I have do the scaling with align tool
and I have talked about the text issues and so on
Questions:
1) How to Convert pdf file into AutoCAD | Insert pdf file in Autocad 2022 |In English,
1) how to set scale when you insert pdf file in autocad any version of software,
3) how to Insert pdf file in Autocad 2022,
4) how to draw any file from pdf in autocad,
if you have any questions just ask i will respond to you as soon as possible
share it to you fellows friends circle, who needs to learn Autocad,
so Don't forget to Subscribe my channel.
Thanks
#autocad #autocadplan #autocad2021 #autocad2015 #autocad2023 #autocad2016
#autocad2022
#floorplan #floorplans #floorplancreator #floorplandesign #learnautocad #learning
regards
Shakeel Akhtar
Step 1: How to Convert pdf file into AutoCAD | Insert pdf file in Autocad 2022 |In English
