How To Create Chess Queen
Chess Queen on OnShape
Step 1: Sketch
Click on Sketch in the top left-hand corner of the document. After selecting the Top plane, draw large rectangles starting from the center point. Your final shape should look like this:
Make sure to use the double arrow button in the top right corner(dimension) to change measurements accordingly.
Step 2: Revolve
Click on Revolve (the button that looks like a C) and select all the faces of the sketch. For the revolve axis, select a vertical line.
Follow the picture!
Step 3: Fillet
Click shitf+F or the fillet button and select the below areas that are in gold. The radius should be 2mm.
Do the same for the selected area below:
Step 4: Transform
Select 'transform' from the list of tools at the top and choose the 'rotate' option. Select a horizontal line when on the 'top' view and rotate the piece 90 degrees.
Step 5: Download
Right-click on the Part Studio 1 tab at the bottom and click 'Export...'
Make sure its the right format and click Export
There you go! You have a queen piece.
