How to design a Steering Knuckle (Request)
==Request Tutorial==
I've spent 3+ hours working on this tutorial just to show you how to design this model in SolidWorks 2016: Steering Knuckle (2D to 3D Request)
Note: The Unit system we'll use is mm.
Step 1: Revolve1
Make a Revolved Base from this sketch (on the Front plane)
Step 2: Cut-Extrude1
Draw a new sketch on the face in the image.
Draw a circle, add a "Vertical" relationship between its centre and the origin then use "Circular Sketch Pattern" command to make the other 4.
The circles' centres must be on the construction geometry (dotted) circle.
Choose "Extruded Cut", then choose "Up to Next" for Direction 1.
Step 3: Boss-Extrude1
Since this sketch is a complicated one, check this video to know how to draw it.
You'll end up with something like this:
Now Choose "Extruded Boss/Base", then make its depth 37 mm.
Step 4: CirPattern1
Use "Circular Pattern" command to pattern (Boss-Extrude1) 3 times around the face selected in the image.
Step 5: Boss-Extrude2
Here we'll use "Convert Entities" command twice: for the outer circle (the dotted one from Sketch2) and for the 3 holes from (Boss-Extrude1)
Choose "Extruded Boss/Base", then make its depth 29 mm (inwards).
Step 6: Boss-Extrude3
Draw one side (the upper one in my design).
Then mirror the sketch about the selected (blue) centerline using "Mirror Entities" command.
Choose "Extruded Boss/Base", add a 10 mm offset (inwards), then make its depth 10 mm (inwards).
Don't extrude the whole sketch, only the part shown in the image.
Step 7: Boss-Extrude4
Select (Sketch5), choose "Extruded Boss/Base",
Under Direction 1 choose "Mid Plane", add a 15 mm offset (inwards), then make its depth 14 mm.
Step 8: Boss-Extrude5
Draw a new sketch on the Front plane.
Notice that the following arcs aren't tangent to the lines on their right, but to the ones on their left.
Choose "Extruded Boss/Base", under Direction 1 choose "Mid Plane", then make its depth 30 mm.
Step 9: Cut-Revolve1
Notice that the 1st selected (orange) line is vertical, while the other line's endpoint is coincident with the 2nd selected (blue) line's midpoint.
Do the same thing below.
Step 10: Cut-Extrude2
Draw this sketch by tracing along the edge, then add the arcs.
Choose "Extruded Cut", "Up to Surface" for Direction 1, then select the bottom face as in the image.
Step 11: Boss-Extrude6
Draw a new sketch on the Right plane.
Choose "Extruded Boss/Base", add a 77 mm offset (inwards), then make its depth 8 mm (inwards).
Ensure that the offset and extrusion directions are opposite to each other.
Step 12: Boss-Extrude7
The endpoint of the arc (from Boss-Extrude1) must be coincident with the selected (orange) line.
Choose "Extruded Boss/Base", add a 53 mm offset (inwards), then make its depth 65 mm (outwards).
Ensure that the offset and extrusion have the same direction.
Step 13: Cut-Extrude3
Draw a new sketch on the Top plane.
Step 14: Boss-Extrude8
Choose "Extruded Cut", from "Vertex", then select the marked vertex in the image.
Make 1st direction 15 mm (upwards), 2nd direction 35 mm (downwards).
Don't forget to uncheck "Merge result" option.
Step 15: Cut-Extrude4
In "Feature Scope", under "Selected bodies", select (Boss-Extrude8).
Step 16: Combine1
Go to Insert > Features > Combine, or search for it in "Search Commands"
Choose "Add", then select both bodies.
Step 17: Sketch14
Draw 2 points, then make them horizontal with the circle's centre.
Step 18: Plane1
Under "Reference Geometry", choose "Plane".
Select the face first, then make it "Perpendicular".
Select the 2 points from (Sketch14).
Step 19: Cut-Revolve2
Draw a new sketch on (Plane1).
The line's (on the right) endpoint must be coincident with the top line's midpoint.
Use "Convert Entities" to convert these 2 lines from (Sketch7), then add a relation between them and their correspondents in the sketch (Equal relation).
Step 20: Revolve2
Make a Revolved Boss from this sketch on the Front plane.
Now your model should be like this:
Hope you liked this tutorial...
