HOW TO DRAW A BOLT?
In this tutorial, i am going to show you how to draw a bolt with simple steps in CATIA V5. I glad if you leave a like, it will be encourage me to share more tutorials like this and better. Thanks in advance...
Step 1: HOW TO DRAW A BOLT?
Click “Start”- “Mechanical Design”- “Part Design”.
Select XY plane and create a hexagon with defined dimension (40 mm).
Exit workbench and click to “Pad” and enter the length as 15 mm.
Select bottom side of the shape and click “Sketch” to draw a circle as 12 mm diameter.
Exit workbench and click “Pad” , enter the length as 70 mm.
After padding process, the helix start point must be defined as follows:
Click star and select “Generative Shape Design” from “Shape” section.
Click “Helix” and select “Helix Curve Definition”. Apply the defined dimensions as below:
Go to “Part Design” from “Start”. Select “Plane” and select “Plane type” as “Normal to Curve”, “Curve” as “Helix.1” and “Point” as “Point.1”.7
Click to “Plane” and draw a circle as below:
Exit workbench.
Go to “Rib Definiton” and select the curve, press “ OK”.
