How to make a Powerful Wind Turbine with Acrylic Sheets and 12 Volt DC Motor|DIY Project
![](https://d2t1xqejof9utc.cloudfront.net/members/avatars/3562586/feed.jpg?1479478002)
![](https://d2t1xqejof9utc.cloudfront.net/pictures/files/186884/small.jpg?1590852527)
In this video you will learn how you can use acrylic sheets to build your own 100 Watts windmill.
I will use laser cutting machine to cut blades of the turbine. I have used a 12 volt dc motor from car radiator fan as a generator with some modifications.
how to modify DC motor to use it as generator watch this video: https://www.youtube.com/watch?v=2GU2AD4sEkI
