LINEAR PATTERN BY EQUATION (INTELIGENT DESIGN)
On this occasion I want to show you how to work a linear pattern by means of equations, and you can see these equations at the assembly level, it is very tedious when you have changes in the design and you have to change each pattern and dimension from one to the other. pieces until the assembly, with this method with just click you can modify your linear patterns derived from these equations, I hope you like this tutorial, ENJOY
