Loft feature in AutoCAD
Tutorial by Karajko CAD
Small
How Loft tool works in AutoCAD?
    What is Loft in AutoCAD?
    It is a tool which connects two shapes from different plane and forms a nice solid.
    Of course if you are a beginner these words do not mean much to you so I am gonna show you better.
    I have two shapes here, a circle and a polygon and they are at different planes.
    That may sound confusing because there are not actual planes in AutoCAD like in SolidWorks.What I mean that they are at some distance from each other as you can see on the picture.
    I have activated Loft tool and I need to select cross sections ,circle and polygon.
    After that I pressed Enter and now I have this,already formed shape but it is not finished yet.I need to decide what I am gonna do next,I am going to click Cross sections only,I will cover other options later.
    The result is here,this is what you can do with Loft command.
    Now I have a line which is going from polygon to circle and it is going to be a reference for the next option.
    Here we go again,after I selected both objects and pressed Enter I again have these options.
    Now I am going to choose Path and select the line I drew.
    This is the result.
    I rolled back again and now I have two splines and they are going to be my Guides.
    So I am gonna select Guides and select those two splines.
    And this is the solid shape I got.
    I hope you now know how Loft feature works in AutoCAD,try some examples by yourself and you will understand it better,there is nothing without practice.
    Karajko CAD
Please log in to add comments
