Make a shower drain with Flanged Hole
Here is a demonstration showing you the design of a shower drain grid in CATIA 3DExperience.
The Sheet Metal Design application, based on industry process features, allows you to create quickly a plate that you can bend and add stamp, dowel, bridges, etc.
This video is divided in two parts. First you see how to design the outer plate (using walls, flange and corner relief). The second part deals about the grid's design. In this Part, you will use GSD to create a repetition of points that will allows you to pattern the Flanged Hole Feature.
Step 1: Video
Step 2: Create the plate [Part 1]
* Better to watch the video *
Create a new product called "Shower Drain"
insert a new 3DPart called "plate"
double click on the 3DShape
Switch to Sheet Metal Application
* in Sheet metal, you need to set up the global parameters *
Click on Sheet metal parameters
set the thickness to: 0.2mm
set the bend raidus to: 0.5mm
Add an offset plane from XY plane
put 5mm and reverse the direction
* this will help you during your design *
Step 3: Create the plate [Part 2]
sketch a centered square 200*200m
in the same sketch, add a centered circle Ø160mm
exit the sketch
Click on the feature "Wall definition"
* the thickness is automatically set up to 0,2mm *
select the top direction and lick on OK
* the result should be this one *
Create a wall on the plate's edges
-> Click on CTRL + Click to do a multi selection of the 4 edges
keep the angle to 90deg
for the length right click on value
add the formula
* a panel appears *
double click on the value of the offset plane (5mm)
* in that way, when you move the plane all the wall will have the same length *
In the extremities tab of the Wall panel, add -0,5mm on the left and right side
* from this *
* to this *
Step 4: Create the plate [Part 3]
Add a Flange on the hole's edge
Keep the angle to 90deg
Right click on the value and add a formula
select the dimension of the offset plane (5mm)
* in that way the flange and the wall have the same length *
Modify the value of the offset plane to 2mm
-> Flange and the wall are updated in the same time
Refine the part using the Corner Relief feature
* it changes the straight corner into a round corner *
Select the 2 bend radius of the 2 walls that makes the corner
Set the value on 1mm
Click on OK
* from this *
* to this *
Continue with the other corners
(optional)
You can unfold/fold the part to see if it is correct
* unfolded plate *
Hide the Planes
Step 5: Create the drainer [Part 1]
Go back to the top product in Assembly Design
* it can help to hide the plate part *
Insert a new 3DPart called "drainer"
Double click on the 3DShape
put 2mm and reverse the direction
Step 6: Create the drainer [Part 2]
Sketch a centered circle Ø155mm
exit the sketch
* the result should be like this one *
Create a Flange on the edge of the cylinder
right click on the length value and add a formula
select the dimension of the offset plane (2mm)
Create a sketch on the top surface of the drainer
Draw 4 circles Ø50mm, Ø80mm, Ø110mm, Ø140mm
Exit the sketch
Step 7: Create the drainer [Part 3]
Switch to Generative Shape Design application
In transform tab of the action bar, click on Extract
* a panel appears *
Click on the marble bag and extract the 4 circles
* the circles will now be 4 different entities *
Hide the sketch
Create a point on the center of the top surface (0,0,0)
Create a point repetition on the first circle Ø50mm
add 8 points
Create a point repetition on the first circle Ø80mm
add 12 points
Create a point repetition on the first circle Ø110mm
add 16 points
Create a point repetition on the first circle Ø140mm
add 22 points
* here is the result *
Step 8: Create the drainer [Part 4]
Switch back to Sheet Metal application
Click on the centered point and add a Flanged Hole
right click on the height value and add a formula
select the offset plane dimension (2mm)
Change the height type to the second mode
keep angle to 90deg and diameter to 5mm
Click on OK
In the transform tab of the action bar, select the User Pattern
Select the flanged hole as the object
Select the center point as the anchor point
Select the Points repetition as the positions
-> Click on the marble bag for multi selection
(optional)
If you edit the sketch and change the diameter value
-> the drainer will be updated
Same, if you change the number of instances in the point repetitions
Change the view mode to custom view mode
Hide the points, lines and plane
Go back to assembly and show the plate part
* The result is this one *
- End of tutorial
